pioneer 1000
Burrhead99
11
9
Coldwater ms
2018 pioneer 1000 wont start. constant rapid dash flashing on gear indicator , new battery, new neutral safety sw.
Reactions: TxDoc
Mark in Northern Iowa
465
2,080
Floyd County, Iowa
kramnella.wixsite.com
Howdy and welcome from Northern Iowa
Read the flash codes and KNOW what is wrong.
And post up some pics of your ride, kind of a thing around here.
Have a good day
106,018
4 yrs and first post!
WINNER WINNER CHICKEN DINNER!🥳
Just givin u $hit🤓
Welcome from the Strechen Gretchen State
The first 2 posts have your answer where to start.
Since we helped u get going, can you do us a solid and post up some pics of your ride?
Like stated above its kind of a thing..
Rule #4 Pics Or It Didnt Happen! 😉
Oh and If u fix your issue, come back here and tell us so the next guy like u that has this issue it can help them when they search it.
Burrhead99
11
9
Coldwater ms
Also, need more info…
how many miles?
First owner?
Clutch update done?
Have you done a clutch relearn after u did the switch?
Thanks
2160 miles. Yea did the clutchrelearn,, constant fast flashing dash. Hello Honda flashing also. Have counted 80 fast flashes no long flash..all fuses good. Don’t hear fuel pump. I work nights so might be a while before I get back. Will get pics when I can
Burrhead99
11
9
Coldwater ms
I tried jumping the two wires. Grn and brown on the dtc plug no help ,is there a fuel pump relay, if so where
Rayger143
Rayger143
2,725
23,604
Winfield, BC Canada
Check your grounds. Remove and clean and remount. This has fixed many problems with members here.
37cef81c 3856 47f9 8ecc 2a1c221e6983 jpeg
Reactions: Buggyman
Burrhead99
11
9
Coldwater ms
I checked and cleaned both engine grn. How do u get to frame grn. I have the big skid plate. Do I have to pull floorboard.
Burrhead99
11
9
Coldwater ms
Those two grn didn’t help. Seams more electronic too me. Should you here the fuel pump runnin with key on. I don’t remember. Bought unit new in 2000 even thou it was a 18.
Burrhead99
11
9
Coldwater ms
Still just turns over will not start first problem I have ever had finally got around to getting some pics I hate to take it to the shop
Reactions: Backwoods
NTCPrezJB
NTCPrezJB
President of #NTC
100,763
900,319
Canton, OH
When you first turn the key and the display is doing its Hello Honda startup you should hear the fuel pump pressurize for a second or so.
NTCPrezJB
NTCPrezJB
President of #NTC
100,763
900,319
Canton, OH
Record a video of your flashing dash, post it to YouTube or similar and then post the link to it here. That will probably help you get the help you need.
