P700 Pioneer 700-2 lift
ram5451
ram5451
11
5
Tallahassee
Want to lift my p-700-2
have looked it high lifter 2.5" lift and A-Arm lifts
Anybody have experience with either lifts give your thoughts on which would be better?
Traded in the p-500 just before Christmas. Will post pic's of p700 soon.
Reactions: Bad_bowtie
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
Want to lift my p-700-2 have looked it high lifter 2.5" lift and A-Arm lifts
Anybody have experience with either lifts give your thoughts on which would be better? Traded in the p-500 just before Christmas. Will post pic's of p700 soon.
Congratulations on the new ride. Are you planning on some taller wheels as well? I put that kit on my former Pioneer 700 and it worked well for my needs...
ram5451
ram5451
11
5
Tallahassee
Yes mostly trail riding. Took the 27's off the p-500 and they rub at full turn. just need a little lift to clear and some more ground clearance.
A-arm lift I thank wouldn't change the ride, would I be correct?
Leyendatat2BZ
Leyendatat2BZ
11
31
Texas
curious what you ended up going with? Right now I'm running AT27x11r12 on my 2016 700-2, and it doesn't rubb, but wanting to go up in size to 28" tires on 14in. Wheels, from what I know I dont think it's been lifted, but it does have a pretty substantial amount of clearance, I drive a f250 with 8in lift on 35's and can back my sxs up to the tailgate to transfer bales of hay and they are almost the same height, any help would be greatly appreciated, I'm wanting to go with a Catvos setup, but from what I can find they only produce them for the 1000's
ram5451
ram5451
11
5
Tallahassee
I went with an A- Arm 2" lift. The 27" tires are no 14" rims with an offset. Still have very little rub. Like the A -Arm lift Better then the bracket lift.
Looking to put p-1000 stock front stocks on my p-700-2. From what I've been reading that will give some adjustment.
Sorry it took me so long to reply.
Reactions: Leyendatat2BZ
Leyendatat2BZ
Leyendatat2BZ
11
31
Texas
No thank you, so it's possible to use 1000 parts on the 700? I was thinking the 1000 was bigger /different body specs, it's hard to find alot of custom parts for the 700
ram5451
ram5451
11
5
Tallahassee
From what I have heard the front shocks from a 1000 will fit up on the 700. I don't know this t be fact, still trying to locate someone local that has a 1000 that I can use their shocks to check if they'll fit up.
13,351
64,952
I will confirm this for you right now.
@Tramguage1 has installed 4 front shocks on @jrplaza2008 machine.
You do need a set of bushings though. I believe @RB3offroad offered them for sale at one point in time.
Glock21user
Glock21user
1,824
9,087
Livingston county, Mi.
I can say for a fact the front shocks do in fact fit with either a bushing swap or open up the mounting holes.
The swap is on my machine
(2018 P700-4 Dlx) and I am rather happy with it.
