Thanks so much28s will fit......But if the tire size runs large or later on you get mud flaps or such,It will rub in extreme conditions. I will never run anything smaller again.
27s are the ideal size for the stock 700.
I run 28s on fox shocks with a 2.5 super atv lift.
The ride is amazing and 14"s of clearance.
Thank u when I order new ones I think I’ll go with 14 inch rims with 27’sI run 26" ripsaw tires on stock deluxe P700 wheels. Stock setup. If I had it to do over I would probably go with 27" tires. I'm happy with the 26" tires I have as far as ride and fit. If I were to go to 27" tires, I would probably go up to 14" wheels instead of the stock 12" wheels. I just hated to get rid of the deluxe model stock wheels that I paid for with the machine, so I kept the stock wheels and upgraded the tires.
Does the 14 inch rims and 27 inch tires hurt your speed or power.Thanks so much
Running 27 inch black waters with can am shocks . No rubs ,plenty of grip , some power loss but not really noticeable .
I have 28x10 all the way around. I can tell it has some power loss with 4 people and going up hillI have a 2.5 inch lift and want to keep my stock deluxe wheels and go with 27 or 28S What width for the front and back are you all running?
