Pioneer won't start after washing
ElmerFudd
ElmerFudd
58
108
My brothers 2015 Pioneer with 5800 miles on it will not start after washing. Checked fuses. Any other simple checks we can do??
Reactions: ChadD and TxDoc
108,149
Check your wiring, aka molex plugs for injectors and so on . Might be wet. Typical after wash no start
11,382
84,891
Also check, clean grounds to frame beside the battery. shift to neutral, using tool if needed, to rule out a bad brake interlock switch.
108,149
Let us know what u find?
curious minds want to know!
Reactions: ChadD
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
Assuming it is still not running, I would check fuses, then pull the air filter and spark plug. For the air filter, check to make sure you are not wet there and with the plug out, spin it over a few times and verify it is firing off. Next, I would put in a new plug. Finally listen to ensure the fuel pump is coming on the moment you turn on the key.
