P700 Portals
I
ike775
48
116
yerington nevada
I am thinking of getting portals, I have to back down hills because no low gear on the 700. I put on 27" tires on the 700-4 deluxe Id like to keep 27" tires on 14" wheels will the 15% portals gear me lower than stock with the 27" tires? I do not mind giving up some speed since I put on the 27" tires it barley hit 40 mph anyways.
JenElio
JenElio
75,160
677,640
Loxahatchee, florida
Are you adding portals just for the lower gearing? Or for the added width/height/gearing? Have you considered IGR (Internal gear reduction)
JenElio
JenElio
75,160
677,640
@Alan_Vander is the man to talk to regarding portals and the 7hundos 👍
I
ike775
48
116
yerington nevada
Mostly for the lower gear, but the height and width is a bonus. Do they have IGR options for a 2018 700-4 deluxe?
Reactions: JenElio
JenElio
JenElio
75,160
677,640
I honestly couldn't answer that for you, I own a P1K5. Im sure you could find an answer fairly quick if you read into some of the 700 forum posts. Use the search option up top.
JenElio
JenElio
75,160
677,640
I'm sure some of the guys will chime in here soon, its late on a Sunday so............give it a few 😆
Bastardchild
Bastardchild
1,978
7,251
Orange Heights, fl
Im not sure even little 4" portals will fit inside 14" wheels. You will probably need spacers like I did when I put 6" portals on my P5 with 16" wheels.
SuperATV
SuperATV
1,373
9,607
Madison, IN
www.superatv.com
Yep, you'll be lower than stock with the 15%. I think it comes with 26" stock right? It'll be pretty powerful. They'll work fine in your 14" wheels as long as you don't have too deep of an offset. Can't really be over 5" of offset. You can probably also go up a tire size at some point.
Reactions: ike775
kamikaze
kamikaze
74
160
Linden, NC
Went riding this weekend with a guy that had portals, gear reduction and big tires. He ended up breaking a tie rod, the portal gears and the tire off the rim going through a hole that I went through stock on 28s. Had to winch him out lol. (Got to use the new Harbor Freight 5k lb rear winch, so that was fun. Pulled it out with ease)
Another Honda guy that I know broke a rear portal shaft completely and had to drag the rear end back with the tire in the bed.
Seems like portals just cause more problems than they're worth.
