P1000 Power on harness plug?
Biggun150
Biggun150
NC
Got the Nilight 5.7's mounted. Bought the power on harness from the store. My ? is what kind of plug do I have to have to connect the Nilight harness to the power on harness. Can I get it at auto store or Honda dealer? Is it a common plug?
20220606 172517
115,419
Are you talking about what switch Do u need Or something else?
a pic of what your asking about would help
Reactions: WagginTail
kandt
kandt
126
762
Bluegrass state
Is this what you got from the store? And are you running a dual battery or just using the main battery?
Biggun150
Biggun150
NC
Screenshot 20220606 183452 Amazon Shopping
This harness single battery
kandt
kandt
126
762
Bluegrass state
Biggun150
Biggun150
NC
This is a wiring harness from Nilight. 14awg based on description and with a rocker switch. Others can give you better idea of how to wire it all up. Think you got the key on power, so you can use it to trigger the switch to use the lights when key is on. Not sure this is the direction of your question. Nice looking machine.
I have the Nilight Sasquatch harness and honda store key on harness. Are they plug and play or do I need another plug?
66,853
Either of the key-on power harnesses are designed to be relay triggers.
They will power a few small things. A set of cubes or 12" light bar. It shouldn't power much more than that.
Reactions: Lady01 and kandt
