P1000 Powering honda/Warn winch with a dual battery setp
G
GGreen
82
99
Amherst, MA
I'm rounding the clubhouse turn on my winch install. Replaced the bumper with the bumper/brushguard this AM and installed the Warn winch. (Not being an octopus, and having no help handy, my 120v Warn portable winch worked a treat. Just hoisted the brush guard into the air and rolled the machine up to it. Good thing, too, because even if I'd had help, at any given moment only 5 of the 6 bolts would line up. After much cursing and a little Dremel grinding work, finally got them all in at one time.) Thanks to all the good advice I've received here, I managed to route the wiring without dismantling the front end of the machine. (Thanks all!)
This PM, I even managed to get the factory ground cable run from the engine ground to the front of the machine, following the factory main harness, while removing minimal body parts. (Again, thanks! Just knowing it could be done helped me do it.)
So now all the wires are up under the hood. I'm ready to hook the engine ground to the winch relay. The winch install kit includes a battery cable that the instructions show running to the starter solenoid, but I have a dual battery setup with a True Am isolator, and I want to power the winch off the second battery.
Is it as simple as just running the hot side of the winch relay to the positive on the second battery? I presume there would be no power draw unless the remote winch swith is activated? (I also have a seondary Blue Seas fuse block, but I'm guessing I shouldn’t run the winch to that, too high an amperage draw, yes?)
Pretty basic questions, but my electrical knowedge is pretty basic, too!
Thanks!
Reactions: BWAF
OnTheJob
OnTheJob
426
925
Bristol, NY
Yes. Directly to the second battery. Not a bad question because it took me a little to figure that out. If you go any other route you limit the amount of power to the winch.
Reactions: GGreen and BWAF
G
GGreen
82
99
Amherst, MA
Thank you, sir! I'm on it this AM, so I should have an operable winch today! (Or a smoking lump of melted plastic and charred steel, if I messed up any of my other wiring. :) )
Reactions: BWAF
BWAF
BWAF
I get paid to pass gas
8,864
42,477
Carthage MO
Lol
G
GGreen
82
99
Amherst, MA
Lol
Success! (Defined as, "The winch works as it should, and nothing caught fire.") Momentary heartbreak on the first try when nothing happened. Checked power at the relay and had no voltage, then realized the machine needed to be running. Started it up and, Hey, Presto!, a working winch! Despite the fact that it's a kit, and I basically just followed instructions, and lots of good HSxS advice, feeling unreasonably satisfied with myself.
BWAF
BWAF
8,864
42,477
Carthage MO
Well done sounds like your luck is as good as mine . But ya know the sun even shines on a dog's ass every once in awhile .Lol sounds like a beer 30 to me
Reactions: Mudwing
G
GGreen
82
99
Amherst, MA
Now it's on to puzzling out how to add a winch in/winch out dash rocker switch into the circuit. There may be a fire in my future yet.
Reactions: BWAF and Mudwing
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
They're pretty simple. Go to otrattw.com and get one. Then just tie in a couple wires.
208,728
Nope its built in to the control box. Wire it into the same wires you're already using for your current switch.
This is confusing, my dual battery set up I just powered up fuse block and winch ran winch control wires to fuse block and works great?
Reactions: BWAF
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
That's not how you do it sir. What's your switch wired to?
Reactions: BWAF
G
GGreen
82
99
Amherst, MA
"I see", he said, "as he picked up the hammer and saw."
Thanks!
Reactions: BWAF
208,728
My aux battery powers a fuse block that the switches are tied into and the main power to the winch is wired to the aux battery like stock. I run all my accessories off this fuse block. That is powered by my aux battery. There is nothing running of my primary battery, that isn't stock draw. I've got my whips, light bar and winch all powered by the aux battery. I forgot to mention I'm running a battery isolator.
Reactions: BWAF
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
When you run the winch is the power carried by the switch or is it run through a solenoid?
Reactions: BWAF and Smitty335
208,728
Has to go through a solenoid unless you have one heck of a controller, fuse block. All I did was switch winch main power source from one battery to another and use aux battery to power the switch, through a fuse panel. I didn't come up with this plan, I looked at @my99svt wiring and copied it. If you are ever around him, ask to look at his wiring, looks factory!
Reactions: BWAF
