I have a used radiator, machine has less than 100 miles and I touched the top corner with a drill bit 1st tube 1/2" from the side has a pin hole. I read you can JB weld it but just bought a new one instead. Asking $50
what was you doing with the drill ?I have a used radiator, machine has less than 100 miles and I touched the top corner with a drill bit 1st tube 1/2" from the side has a pin hole. I read you can JB weld it but just bought a new one instead. Asking $50
JB weld not strong enough?!? If you can fix a tractor motor with it I'd expect it to hold up against 15psi. BarsLeak is also an amazing product.I'm guessing JB weld won't be strong enough. Most newer engines have around 15 PSI radiator caps. I haven't even looked at the radiator what does it look like its made from? If its aluminum on the tank it might be able to be tig welded back together.
