P1000 Radio hookup
67,173
Yes. We'll not totally 100%.
The only power would be from the key-on circuit. Like 1ma.
Thats why most use relays. To move the majority of power to the battery of choice.
BigOL3
BigOL3
2,994
8,920
Electrical dummy here ....... any particular type relay needed and any directions on hooking it up would be much appreciated.
Reactions: Biteme
67,173
You should have something like this between the second battery and the fuse box. Then everything pulls off the second battery except the key-on power which is not a concern.
BigOL3
BigOL3
2,994
8,920
You have this in the Store? Does it go between the 2nd battery post on Isolator and fuse box?
Reactions: Biteme
Scoop
Scoop
5,191
20,511
  3. Talon R LV
The continuous relay (the one from the Club store, the Stinger, or the Cole Hersee, whichever you get) is connected between the positive post of the aux battery and one of the two main posts of the relay. The other main post on the relay goes to the positive side of your fuse block (and you ground the negative post on the fuse block). The two smaller posts on the relay are for your 12V source that will energize the relay to connect the aux battery to the fuse block when you turn it on, whether that is key-on power (e.g., use the key-on power harness from the club store or a switch that gets 12V from the battery itself. The isolator itself has nothing to do with powering accessories, per se.
Oh, not sure what year your Pioneer is, but that link for the key-on power harness is for 2016-2021. There is a different one for the 22+ in the Club store.
If you're a bit green at 'lectrical, you might want to watch this dual battery install created by one of our distinguished members, @RobSparre:
BigOL3
BigOL3
2,994
8,920
Thanks Scoop, you explained it well.
