P1000 RB3 GRAB BAR SPECIAL
RB3offroad
RB3offroad
1,701
4,751
Tempe, AZ
RB3OFFROAD GRAB BARS ON SALE FOR 1 MORE WEEK!!!!!
Grab bar 1000
56,677
Have any mounted on a machine that has an SATV folding windshield? I'm interested but it looks like it will interfere with where the lower windshield mounts. Very nice looking piece as usual from RB3!
RB3offroad
RB3offroad
1,701
4,751
Tempe, AZ
We Have not had any issues yet with windshields
tdhanses
tdhanses
1,044
3,553
Kansas
Yeah I’m interested as well but think between the window and doors I’m going to be out of luck.
Reactions: Lady01
TripleB
TripleB
11,665
99,082
Caryville, Tennessee
It doesn't fit with the superatv windshield the way it was designed but I made it fit. I think it's gonna work pretty good. I wont have any real feedback until my wife heals up and is able to ride. The superatv lower windshield clamp is where the grab bar needs to be. If you go above the superatv clamp, the grab bar hits the bracket on the lower windshield. I went above the lower windshield and below the factory grab bar on the cage. I had to trim the windshield in 1 spot so it would fully close. I also put a thin piece of foam on the grab bar clamp because the upper windshield is gonna rest on the grab handle clamp. It's not perfect with the superatv windshield but I believe it's gonna work for her. The grab bar is built solid. I definitely recommend it for people not using the superatv windshield. The only reason I won't recommend it with the superatv windshield is because of the little bit of modification you will have to do and it may be to high for some people where I had to mount it.
20210512 183000
20210512 183010
20210512 183039
20210512 183109
20210512 194158
20210512 194209
20210512 194215
20210512 194559
20210512 194917
20210512 183000
56,677
It doesn't fit with the superatv windshield the way it was designed but I made it fit. I think it's gonna work pretty good. I wont have any real feedback until my wife heals up and is able to ride. The superatv lower windshield clamp is where the grab bar needs to be. If you go above the superatv clamp, the grab bar hits the bracket on the lower windshield. I went above the lower windshield and below the factory grab bar on the cage. I had to trim the windshield in 1 spot so it would fully close. I also put a thin piece of foam on the grab bar clamp because the upper windshield is gonna rest on the grab handle clamp. It's not perfect with the superatv windshield but I believe it's gonna work for her. The grab bar is built solid. I definitely recommend it for people not using the superatv windshield. The only reason I won't recommend it with the superatv windshield is because of the little bit of modification you will have to do and it may be to high for some people where I had to mount it.View attachment 271174View attachment 271176View attachment 271177View attachment 271178View attachment 271179View attachment 271180View attachment 271181View attachment 271182View attachment 271183
Thanks for the pics and review Brad. That's pretty much what I was thinking when I saw it after looking at mine.
