P1000 RB3 Raffle
I’m in for the raffle.
Reactions: Plumber32
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
@RB3offroad what the status of this idea?
103,880
Still don’t know what a steering rack is or now, why I need 3?
320,711
Just a heavier duty steering box is all. There is only one in the machine, it’s what the steering wheel controls to make the wheels turn.
The only way you’d really need to be worried is if you were taking out tie rods (front steering bars) and went aftermarket heavier duty with would send any damage up the line to the steering rack.
Good idea for running long length control arm and portals as well.
With that said an upgrade is an upgrade, a good deal on one and I’d install one in mine happily lol.
Can the steering ratio be changed? I guess I should ask can it be changed without increasing much cost because I assume RB3 is reusing the stock gear set.
RB3offroad
RB3offroad
1,704
4,770
Tempe, AZ
We had the rack and pinion made. The Rack in is a 1.125 chromoly and we changed out the internal. no more plastic its now with a metal bushing. the housing is also a billet housing now as well. I was just waiting to see if there was enough interest on this group to run the raffle. The steering ratio at this time is the same but we have been looking into a faster ratio but that would be further down the road.
We had the rack and pinion made. The Rack in is a 1.125 chromoly and we changed out the internal. no more plastic its now with a metal bushing. I was just waiting to see if there was enough interest on this group to run the raffle. The steering ratio at this time is the same but we have been looking into a faster ratio but that would be further down the road.
Thank you for the feedback.
I was thinking a little bit lower gear set to help with bigger tires or portals.
Reactions: CumminsPusher
