P1000 Rear Bench Seat
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
I thought I would post a couple of picture of my new bench seat that I made, are children love it as it give them more cushion then the factory pads and they sit up higher and can see out better.
1014160837 1014160838a
That is awesome! I'd like the details too.
Signature:
QUOTE by Tflynn, "The aftermarket doesn't build what you want? Show them your favorite finger and build it yourself!"
Reactions: CumminsPusher
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I'm in for details as well. Is it easily removable? Details man details!!
Reactions: joeymt33
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
That is pretty sweet. Care to post the build details?
Went on Ebay and bought high density upholstery foam High Density [HASHTAG]#FoamTouch[/HASHTAG] Upholstery Foam size 6" X 24" X (41-49)" Custom Cut | eBay six inches thick for the bottom and two inch thick for the back, got the upholstery fabric from are local fabric store.
After a lot of measuring marking started cutting on the foam until it fit, on the center cut I used a skill saw with a regular wood blade in set to depth it cut nicely when there was plenty of foam on each side to support it when I cut the edges to depth on a angle it tried to take a bite I used a sharp hunting knife and a razor blade to cut on it, also a used a angle grinder with a sand paper flap wheel to trim on it but you had to be careful not let it grab it.
After that laid the foam on the back of the fabric marking it out with thee quarter inch extra to sew together them my wife set me up on her simplest sewing machine (She has almost as much money spent in her sewing closet as the Pioneer) and watch me frustrate my self :) she didn't help me sew anything but did rescue me a couple times when her machine quit sewing and sweetly reminded that I had previously said resetting a feed line that timed out was as easy as changing a bobbin. LOL
Reactions: PioneerPete
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
The bottom pad is fitted and just sets in there with out moving around, the back I put Velcro on the top corners I don't no if that is going to last though I may had to think of something better.
Reactions: Delton
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
So the bottom of it is just a pad and not hard material like wood or plastic?
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
very nice! I'd be a hero to my kids if I made something like this!
I'm sure you already are man. But....if we had some 1/2" square tubing for the frame, I bet we could make some.
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
Yes the bottom is just a foam pad.
There is no rear roll cage, or seat belts this is primarily a farm use machine that being said by adding a notch in the rear of the cushion your seat belts should work fine.
N8theGR8
N8theGR8
74
Central Texas
View attachment 24794 View attachment 24795
Nice work man!! Nothin wrong with runnin a sewing machine, changes things up. Can make your clothes fit if your between sizes. My brother has an upholstery sewing machine, these are good lines man, 100%!!
Reactions: GPR1500SC
