P1000 Rear floorboard melted
Koda
Koda
565
2,309
Canton Ga
NO HEAT SHIELD! I think mine has Two or maby even Three
Mine has heat shields from just past there back but not right by the floorboard.
Reactions: sharp
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Heat from the exhaust would be more wide spread I would think. Your hole has a distinct shape to it. More inclined to agree with the others that suggested something got caught underneath and caused this. The area surrounding the hole would be wavy if heat from exhaust did this. But I'm definitely no engineer so just guessing.
Reactions: Tigermark and sharp
The heat is focused in that area
A941200ab4207637b7d2ec7f353f29b2
It's very close to the exhaust but I'm leaning toward a secondary source that boosted the heat. Mine doesn't have a heat shield right there either, but trying to get it hot I haven't been able to get it over 200 which shouldn't melt plastic.
Reactions: sharp
Koda
Koda
565
2,309
Canton Ga
No signs of any burnt matter on the driveway when I washed it out and no sign of any burnt place on exhaust
Reactions: sharp
rkwerner
62
134
I would certainly take it to the dealer and have them document it. If nothing else to cover yourself should something happen in the future. There have been a few reports of them burning and in the pictures I have seen they are so destroyed there is no way to determine a source. Honda make take this serious as it could show what has caused the fires in other rigs, however if you get it documented you have a pretty good source to push should yours burn in the future. Document it well report it to Honda and file everything together just in case.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Yes heat is in that area but look at the hot area in your thermo then look at the small hole. Big difference in area there. Just wierd that a larger area wasn't melted.
Reactions: sharp
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
It melted it shouldn't of Honda should cover it. They need to put extra heat shield there.
Low end FLIR temps are correct, checked against boiling water and other known temps.
White doesn't show gradient well it skips to black when it's out of range. AND it auto ranges based on majority of image so it's a narrow range.
19f346d82e5f5cf315ecab9961dfcf9a
Highest temp I could find was right where cross hairs are in my images.
Koda
Koda
565
2,309
Canton Ga
Looking at your images that looks to be exactly where the hole is
Reactions: sharp
Yeah but melting point of HMWPE is over 265-280F and 200 is highest I've ever had it's usually around 150 or less when I've run it hard and measured it.
Under heavy constant load climbing mt at speed?? I can't duplicate that here no grade long enough I can drive pioneer on.
Reactions: sharp
N
nsolimini
Lakeland, FL
I wonder if this could be something? Wasn't there someone on the facebook group who claimed their pioneer caught fire? I wonder if something like this was the culprit.
Reactions: Delton
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I seen that. According to them it was just parked at their residence. If I remember right it was totally cold. Hadn't been driven recently.
Reactions: JTW
Plongson
Plongson
271
1,027
Southern Utah
Ohanacreek, nice camera. Are you a thermographer? In my years of predictive maintenance using primarily vibration technology, I did pick up a Level II Thermography cert from the Infrared Institute. Used FLIR equipment from way back when you had to chill'm with liquid nitrogen...LOL (Ya, I'm frigg'n OLD) I always preferred the "Iron" color scheme...Thanks for the thermo shots...
E
elkguide
3,377
7,964
Vermont
Was that right after the pinhole cameras?
Nope I'm sales, we use them for various reasons.
Reactions: sharp
hondabob
1,291
5,124
Prescott Valley, AZ
Take it to your dealer so they can take pictures for a Honda report and compare the heat shield with another Pioneer. They can text the pictures to the Honda service rep and tech line.
Reactions: sharp and Koda
Koda
Koda
565
2,309
Canton Ga
IMG 1135
Got my ride back from the dealer yesterday. They installed the cabin comfort kit and replaced the rear floorboar. The new one has a small piece of thermal heat barrier material on the back where the hole was burnt in the old one.
