Just took it off -- 2018 P500 with WE shocks -- ( 2 Put on P520 )
Made & put on in 2018 - Been on all 5years <> "NO PROBLEMS" <> "Never Came Loose or Shifted" <> Sway Bar - ALWAYS "ON" -`Never Unattached.
DOES Move Shock Mount to OUTSIDE of Frame.
OEM Shock Mount Behind Top Frame Rail <> Holds Center Ft. To Rear <>& <> 2 bolts down the backside of top frame rail Hold Side to Side.
See the pictures:
Over time have had several rear view pictures of 2018 P500 "No One" ever Noticed Sock Mounts outside frame.
The reason it was done Last picture ( tend to Fill that Dumpbox with fire wood.) kept from bottoming out with load & vary little effect ride quality.
Utility Use Not just trail riding? -- Compensate the load & ride quality by Adjusting the WE Shocks.
See the pictures:
