Hi guys, just was wondering did a spanner wrench for the rear shock adjustment get included in your tool kit when you bought your machine. I would like to adjust mine for some heavy loads and didn't want to use a pipe wrench..... Thanks
I used a good pipe wrench with no issues. Just make sure your threads are clean and also.... it makes it much easier if you pull the top shocks mount bolt and leave the lower as is.. then just lay the shock on your lap and adjust. Just my .02
