![Tuco69](/data/avatars/m/9/9197.jpg?1541941075)
Tuco69
A lot more pronounced riding behind it. What causes tow out?
You are in the Talon forums but your profile says you own a 1000-3.A lot more pronounced riding behind it. What causes tow out?
"More pronounced"??? Did you actually measure it or are you doing some sort of visual toe check?
Bent frame.
Bent suspension parts.
Worn out suspension bushings.
Moved to P1K area.Shoot, wrong forum area…..thx. 1000-3 2017, not abused or wrecked.
You are correct. Thanks! We do haul a lot, animal feed mainly.Moved to P1K area.
Are you sure you are mistaking camber for toe ?
P1K are notorious for showing rear tires canted in at top as if camber is off. However it's just the springs compression from factory assembly.
The more weight carried in bed over time the more pronounced it appears. If you put a jack under the machine and raise the frame you will see the camber correct itself as the A arms move.
