Recommendations for cell booster
Vikes79
Vikes79
SKOL!
11,709
113,610
South Dakota
  2. Talon X4 LV
Hey all, looking for suggestions for a cell booster.
getting tired of crappy signal when I’m ice fishing, camping, driving in western SD etc.
I’ve looked at the Wilson setups, but wonder if there are better for lower cost.
Ideally I’d like something I could move rig to rig as needed, and still be 12v... maybe even for trail riding as well?
suggestions?
Reactions: BWAF, sharp and JTW
russknight
russknight
1,910
7,510
Perry Florida
We are a WeBoost distributor / dealer. I have one in my side by side and they work well. You will have a stronger signal in marginal areas, and coverage in areas where you didn't before. Couple of important things to consider. Interior and exterior antenna separation must be at least 6 feet apart, which can be difficult sometimes on a side by side, and the boosters are not waterproof or even water resistant.
Vikes79
Vikes79
SKOL!
11,709
113,610
South Dakota
  2. Talon X4 LV
Thanks for the insight.
Approximately close does your phone have to be to the interior antenna?
6” to a 1’?
Reactions: BWAF
Vikes79
Vikes79
SKOL!
11,709
113,610
South Dakota
  2. Talon X4 LV
How about something like this?
Maybe this is a bit more portable?
For my rv / ice fishing needs it would more for streaming or hotspot as I usually have my work pc with me.
Reactions: JTW
russknight
russknight
1,910
7,510
Perry Florida
6” to a 1’?
Not sure, but it's more than that. It also depends on the tower signal strength. I'll see if I can find out.
Reactions: JTW
Vikes79
Vikes79
SKOL!
11,709
113,610
South Dakota
  2. Talon X4 LV
Pulled the trigger on this booster plus the upgraded magnetic mount antenna and a carrying case for storage.
E0ADBAB4 CDDD 4C08 9A1E E0E98CDB222E
Hopefully I’ll be able to report results this WE.
Reactions: JTW
russknight
russknight
1,910
7,510
Perry Florida
That's what I have and sell. You will see a difference. You might want to purchase the antenna I've linked to. It gives you more gain / range and is inexpensive.
Antenna
ERICMADERE
ERICMADERE
22
Kiln MS
I would also like to know how good this is as I am looking into some for my boat. Where we fish, after so far out you lose cell signal which ain't a bad thing most of the time.
Reactions: NTCPrezJB
Vikes79
Vikes79
SKOL!
11,709
113,610
South Dakota
  2. Talon X4 LV
So the booster, carrying case and better truck antenna arrived today.
C7153664 3105 468D BA3C BB64773AA41C
Using a 12v converter in my house I was able to tinker with it a bit. My cell coverage in my house is usually a strong 2-3 bars.
With booster off
CEEDDEE9 59BF 4FB9 B7F5 4FFA5909842A
With booster on (bump to all bars on my phone)
DB49D745 B31C 480A A256 D892FAAB8D09
It’s not quite a realistic test as I’m already in a spot with good coverage, but there is definitely an improvement.
Tomorrow I’ll try it in and area that I know the coverage is kinda poor. I was also just using the antenna that came in the box.
Reactions: Mudwing and JTW
Does it work while driving? I’m reading some comment saying it doesn’t work as well.
Vikes79
Vikes79
SKOL!
11,709
113,610
South Dakota
  2. Talon X4 LV
Yes it works fine while driving. It will automatically derate or turn off it’s boost if you are already close to a tower.
So far it seems to work well. I think I’ll be adding a fixed antenna to my RV so I don’t have to fish the antenna wire all the time.
In a few weeks I’ll be traveling to areas that are very weak on cell service, that will be the true test.
Well, I’m prolly going to order one now and try it out. Is the other antenna necessary? What’s the point? I would have thought the antenna it came with was good.
Vikes79
Vikes79
SKOL!
11,709
113,610
South Dakota
  2. Talon X4 LV
As I understand it, the other larger magnetic mount antenna has a higher gain vs the in box antenna.
Reactions: JTW
Vikes79
Vikes79
SKOL!
11,709
113,610
South Dakota
  2. Talon X4 LV
Thought I’d make an update. This week I have my booster in my P1k5 while out and about in the Black Hills of SD.
Cell service is very spotty in the hills especially when you are in the bottoms.
Several times I’d have a 1x service signal, bump on the booster and I’d be up to a 3G signal at 2 or 3 bars.
Definitely worth the investment if you are riding by yourself.
I used some 1/8” steel plate about the size of a beer can bottom and taped it with gorilla tape to my roof and used the magnet mount antenna.
A1936331 63C3 40E6 B376 2A08D8363229
The cable is just long enough that you can route it over the passenger side roof line, down the front and into the under dash storage bin if you have it. Plug the cig lighter adapter in to your booster. I have the phone side antenna run up to my Ram Mount phone holder.
A167DA2A B1E0 4AFF 8110 6EE078A9564BF6D5A731 483B 43DD 87C4 48D481E43128
