Looking for ideas on a rear light bar for 1000-5 I have the kolpin steel roof and would want something that would clamp to cage and be under roof lip .
Thanks
A simple and easy solution to install a backup light. This is a simple and easy solution for installing an auto backup light. It is fully plug-n-play, drop-in ready. The kit does not require any wiring, cutting or splicing of the factory wires. Simply clamp the preinstalled light, feed the...
Do you have an Auto Backup Light on your Honda Pioneer 1000? Would you like to manually control this light without having to be in reverse, allowing you to use them as a work light? Introducing the Manual Worklight Trigger for Automatic Backup Lights. This harness adaptor works with most...
store.hondasxs.com
Add this to the light kit posted above and you will have what you want.
Hey thanks , just made my first purchase PBR products ordered Friday and received package Sunday , very pleasant and helpful , and knowledgeable person I dealt with
