![Upstatefreedom](/data/avatars/m/4/4795.jpg?1465045615)
So I got my new P1k3 last month. First short ride out back on the trailed was great. Just getting used to the dct. I traded in a ranger because I'm not a fan of cvt. (And Polaris). Anyway, after hitting the trails I went up the road. The trans did not want to shift out of 2nd. If I pushed it more 5-5500 rpm it might shift. Then the other gears Maugham do the same. If I used manual the shifted fine. Next night I found when engine cool it shifted fine. When at temp it would not. Checked fluids, grounds and connections. All were good. Even disconnected the battery for a day. After the third day and only about 12 miles on the odometer it stared shifting fine,cold and hot. I now have 105 miles and have not had the problem since then. 1st oil change looked good. Nothing on filters and oil was clean. I may have a little shudder when in 4 lo crawling over rocky terrain. But might just be the design? Just curious if anyone else had the same issue and if I should be concerned. I'm going to see. How it goes for a while during the warranty. Other than that I am in love with this beast of a sxs!!!!!!
