E
I’m wanting to put 28x10x14 tires all the way around with 5+2 offset with 1 inch spacer in the rear what size rims do I need I have a 1000-3 deluxe
Stop it, troll! 🤣🤦♂️
African or European?How big of a tire can you run without a lift?
🤔.......depends on what kinda blinker fluid you use.How big of a tire can you run without a lift?
Asking for a friend
I recently switched to synthetic. I get at least 2 extra blinks per minute now.🤔.......depends on what kinda blinker fluid you use.
You trying to cause an accident?!?I recently switched to synthetic. I get at least 2 extra blinks per minute now.
I thought fast blinks meant you had a bulb outI recently switched to synthetic. I get at least 2 extra blinks per minute now.
I run the 12v-30 blinker fluid. I read somewhere if I ran that fluid I could run 33’s🤔.......depends on what kinda blinker fluid you use.
At least......I run the 12v-30 blinker fluid. I read somewhere if I ran that fluid I could run 33’s
Man, I love this site, everyone is so helpfulAt least......
Smitty???Im confused!🤯🥳
