Rims and tire pic request
Millman13
Millman13
32
94
Tennessee
I’m thinking I would like to get 16” rims and 30” tires. My pioneer has a 3 in lift and I think it’ll fit just fine. Does anyone else have this set up? If so I would appreciate a picture! Thank you!!!
Russ989
Russ989
22,641
147,235
I put 30x10x14 and a 3in lift and they rubbed like crazy lol.you will definitely need A arms to clear 30s. There not hard to put on @Russ989 has an install video I think.
True story, without forward arched A-arms it’s going to rub like hell.
Ridinfool
Ridinfool
36,144
386,046
Western North Carolina
Something to consider when choosing wheels and tires is how much sidewall will you have? More sidewall means you can air down if rock crawling and still protect the rims.
Less sidewall it will be harder to air down and still protect the rim. I’ve not seen 16” wheels anywhere, only 15” good luck in your hunt.
tdhanses
tdhanses
1,044
3,553
Kansas
You will be close, I have the 30” maxxis rampage, when I first aired them up I only went to 12psi and they measured a hair over 29” , so the carnivores may measure short as well, if you don’t air them up much more then 10psi you’ll probably be ok. I’d still get the SATV forward a-arms, easy install and not extremely expensive compared to wheel and tire costs.
I‘ve since aired them up to 20psi and bet my tires are closer to a true 30”.
Something to consider if you run a low psi like 10 or lower, you may get pinch flats as I believe the carnivore has a soft sidewall, think most ran them close to 15psi to not ruin tires But I’m just going off memory but the lower the psi the shorter the tire but also the more you risk ruining a tire, always trade offs.
What offset are the rims?
Millman13
Millman13
32
94
Tennessee
Good info! Thanks for the reply. The offset is below. I also have 1.5 inch wheel spacers on all 4 if that makes any difference?
WHEEL OFFSETS (F/R)+10mm / +10mm
Millman13
Millman13
32
94
Tennessee
Well they fit! The are 29x9.5x15
07CD67A5 506D 461C 9D69 AE37D4E7F4DA
34B32B65 FEB8 487C BD25 DAE2330E314D
TripleB
TripleB
15,115
134,714
Caryville, Tennessee
Hey B,
What r you running 4 front rims on ure rig or stock rims? Im thinking of doing same as you but with the 30" BLK Water EVOS
I'm running 28" EVOS on 4 front 12" steel wheels now. I have 30" evos and superatv arms to install. If I don't ride this weekend, I hope to get them on. I'm gonna put the 30s on the front stock 12" wheels also.
JenElio
JenElio
72,982
664,813
Loxahatchee, florida
Yeah that's what im thinking of doing also.
I thought that's what you had going was 4 fronts but I always forgot to ask.
30/10r12 ?
Reactions: TripleB
