Talon RotoPaks
dankathyc
Has anyone looked into mounting RotoPaks on these? Disappointed that the fuel tank is the same size as our 800 rzr. 100 + mile rides are pretty common. Need to carry more fuel. Wished the tank would have been at least 10 gallons.
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
Did you actually ride it or are you assuming that the tank is too small? It's pretty easy to get 20-25mpg in a Pioneer, I'd expect the lighter talon with a taller gear ratio to perform very much the same.
Reactions: JTW, lee and sharp
dankathyc
i am assuming that a 100 mile range is in the ball park and it is common for us to exceed that. have never been around the pioneers, but 25mpg with some low range trails involved sounds pretty good. does anyone have some knowledge of the talons range yet? i was trying to envision how my rotopacks could be mounted on the talon
Reactions: sharp
Just have to see when someone gets some trail time.
There are several folks that make mounts.
Reactions: JTW and sharp
Talonpalooza
Talonpalooza
122
237
I thought one of the reviews I watched said they put over 120 miles without refueling. Don't take it as gospel, but I thought it was in one of the Sand Hollow videos.
Reactions: sharp
Killer223
Killer223
265
530
i'll have some trail/woods time this weekend and will be able to tell how it does, i am also looking at the rotopacks, my commander would go 150+ ona tank easy, and often, hope this R does as good.
43,293
There are a bunch of people here who are waiting to hear how it does.
Reactions: Mopower58
HondaTech
Theres plenty of cage to mount a rotopak to. Maybe on the downtube going into the bed?
dankathyc
thats where i was looking - in the pictures it looks like the out side of those tubes would work well. ideally, it will comfortably run 140-150 miles without fueling and then we wont worry about it.
RideRed85
RideRed85
61
80
WV
The good thing about RotoPax is the versatility. You could mount one about anywhere on a SXS. I'm coming from a Rzr 800 S and am used to carrying extra fuel. It was a glutton for gasoline. It's also nice to have some extra fuel with you in case you come across someone else who has run out.
T
The-Bearded-One
20
37
North Idaho
Having a hard time finding a good Rotopax mount for the 2 inch roll bar. Anybody else have better luck with this?
bjniceguy
322
431
Iowa
keep in mind that if you mount the rotopax outside the cage and roll on side, it could be an issue. Inside the cage or across back "should be safer". I was in accident a couple years back with the "bracket only" on outside and it ground 1/8" off bracket (lucky testing mount with tank on rear). No problem.
DRKnight
136
269
Yuma, AZ
On the fuel mileage side my X has been in the 16.7 - 17.4 mpg range on each fill up.
I was hoping for the 20 mpg range, but don't look like it will ever happen....DRK
jasond
jasond
221
352
Indiana
I got 105 miles on my first tank and still had over a bar of fuel when I filled up.
I did 140 miles at Brimstone and used 9-10 gallons total.
Reactions: Ragnar406
K
KenThompson
280
622
Mulino
This works great for extra beer and 4.5 gallons of fuel, and still room for the dog!
AF9CBA4A AAFF 433D 85F0 B42C5089EA6A
FC3FFC6F 4745 46AF A93D AB7045E46EDD
