Talon some additions.
Killer223
Killer223
265
530
Got the LED light bar installed and wired to use the high beam switch, works perfect.
Got the LED license plate holder installed. and wired to tail lights.
Horn installed and operational.
Rear view mirror installed.
Whats left is an intercom system, likely using aircraft parts. and a radio.
Radio will be a BTECH UV-50x2 and some hard mount antenna.
IMG 0728 IMG 0729 IMG 0730 IMG 0732
viceversa
viceversa
20
Flagstaff, AZ
Nice! curious about how you used the high beam switch to control the light bar. Also, I'm in Flagstaff as well and will picking up my Red R this week!
Reactions: Blownzuki
Killer223
Killer223
265
530
I just found the wire that is hot with high beams, ran that to the positive for the light bar. Bigger light bars I would have used a relay. But my small light bar has low amp draw.
Hit me up! Well go ride!
Dhalli44
5
Arizona
What two wires did you take the black and white wire from the LED license plate bracket to. I have three that go to my brake light. Brown, green, and green with a white stripe.
Killer223
Killer223
265
530
cant remember right off. i'll have to look after the ride tomorrow.
Doogle
Doogle
186
249
Surprise,Az Cincinnati,OH
I just attached mine the other day. I ran the ground to a bolt coming down from the cargo bed. Here's my post with #5 having more of my thoughts about the wiring.
