Hi Folks,
I have Camso tracks on my P1K-5. The tracks gear it down aprox. 60% so if my speedo says 50 mph I'm really only doing 30.
It drives and shifts fine as is.
I need to correct my speedometer error and through searching I've found a couple products like 12oclock labs and Healtech that correct this issue.
However, the problem I worry about is that I have also read that the P1K-5 gets speed signals from 3 different places. The front diff, the rear diff. and the subtrans.
My question is do I need to correct all of the speed signals or can I just correct 1 to get my speedometer to read correctly?
If just 1 then which one and where is the wire harness for it?
Thanks,
Jason
Thanks,
Jason
