There isn't really a resistance check for the pulse coil, the only way i know to check for proper operation is output voltage at the ecm. But you would need a peak voltage tester or ignition analyzer to catch the pulse voltage, a normal multimeter wont catch it.
The blue/yellow wire and one of the green ground wires at the ecm connector are the 2 wires needed to test. If you have the proper equipment you should get .7 volts or more while cranking. If no voltage is present at the ecm, then test at the pulse generator connector and if voltage is present there, then the issue is between the harness and the ecm.
You can also check for input voltage to the ecm on the black/red wire in the 5 pin connector on the ecm with the key on. Should be battery voltage, if that's missing check for a blown ignition fuse or bad main relay.
Since your not getting any fuel or spark, it sounds like a ecm failure or ecm not being powered on.
Can you retrieve codes from the ecm on the dash?
Does the check engine light come on and go off when the key is turned on?
Does the CEL stay on or blink any codes?
