Store Login
russknight
russknight
1,910
7,508
Perry Florida
Does the site store require a separate login from the board? Also, I want an indicator light on my dash to illuminate when the fan is running. Can I accomplish this with the fan override kit?
65,985
Sorry, its a different login. They are u able to merge.
Yes. But if that's all you want it would be best to make a custom one that will splice the + and - with small guage that can hook directly to whatever small led you have.
Unless your future has a need for the override.
Ok. Let's talk.
Thansk.
Reactions: russknight
russknight
russknight
1,910
7,508
Perry Florida
I have a small led indicator light that I would like the harness to activate. Whatever you suggest, jut let me know how much.
Thanks!
65,985
Ok.
What machine?
If the light is all you want I can make that happen with no extra cost.
I will try to guess the wire length. Unless you have a 1000 then I can test fit mine.
You will have to just wire up the + and - to something like this but I can only find green. https://www.amazon.com/dp/B07MR6TVQM/?tag=sxsweb24-20
aauman88
aauman88
1,091
2,846
Ok.
What machine?
In the question area the seller says they can change them to any color you want. Good idea too, I will be adding one shortly.
russknight
russknight
1,910
7,508
Perry Florida
Ok.
What machine?
Pioneer 1000-3, and that is the LED I have.
