went and llooked at my talon, front only, looks like caliper won't lift away from rotor with wheel on, maybe someone knows if it will, it would be a slam dunk if it did
if I had to, could get to the rotor bolts, back them out and leave rotor loose
remove axle nut and the wheel hub comes off and grind the back of the wheel stud away - looked like a lot of grinding with a Dremel tool, could get to it if I had to - looks like a royal pita
-agree that start by centerpunching the lug nut and start small and work your way up, lots of patience\lube on the bits and then try splitting the nut with a chisel or punching the stud back thru the hub, either way I would think if that stud is spinning, the bore is too big for another stud and its trashed
