P500 Super ATV Flip Windshield mod for hood access
txbmcnabb
txbmcnabb
10
50
Texas
Living in the south, I could not see purchasing a windshield that would only open a couple of inches in the summer when you need the air. However, in our cooler times or when I come across spider webs on trails, I wanted something that could block air. I purchased the SuperATV flip windshield knowing that I would need to mod the mounts on the bottom for hood access. I bought hinges at ACE that were the approximate width of the mounts. My neighbor actually did the welding for me so I have no knowledge to share on that part of the process, other than he trimmed the length of the hinges before welding. But the result is exactly what I wanted. I haven't decided on how to secure the bottom yet so will just be using zip ties in the meantime.
The picture of the full windshield is before the mod. You can see there is plenty of space on the mount to weld the hinge on. Also, when flipped up, the windshield stays in that position while the hood is removed.
IMG 0520 1 IMG 0761 IMG 0760 IMG 0759
lee
lee
Village Idiot
2,385
13,501
Springfield Ohio
You can get the Honda can lock clamps like the roof uses, I think the part number is 08R70-HL3-A00 .
(Check the part # before ordering)
lee
lee
Village Idiot
2,385
13,501
Springfield Ohio
It was like Christmas waiting for me on the front porch toady when I got home.
Ordered some ROPS clamps from amazon and some side wall warts and other supplies from here.
ROPS clamps are to do exactly what you did and to mount my tablet so I have maps when riding.
Official part number is correct above.
D4953F93 89BF 4A1E B14D 339E93BF1B63
TripleB
TripleB
15,189
135,528
Caryville, Tennessee
Do u need 4 of them to quick disconnect the lower portion of the windshield? A buddy of mine is wanting to order the super atv windshield for his 500.
lee
lee
Village Idiot
2,385
13,501
Springfield Ohio
My plan is to weld in a hinge like @txbmcnabb had done.
Then add 2 ROPS clamps at the bottom so I can un-toggle the clamps and flip the lower half up.
You could use 4 clamps and skip the hinge.
Undo the bottom 2 clamps, just flip the toggle on the upper 2 and slide the lower part up to clear the hood.
Reactions: JACKAL and TripleB
txbmcnabb
txbmcnabb
10
50
Texas
I never completely mounted my mirrors correctly as I was waiting to get the windshield mod completed. I want to keep the mirrors so the ROPS clamps are probably too large for me. Someone else on here also did the mod and had some sort of push pin locking mechanism. I'll see if I can find that post.
hallic
hallic
320
1,795
Central MN
I'm trying to figure out how to keep 4 clamps on for stability, and also use side mirrors. Might just end up ditching the bottom 2 clamps for mirrors.
txbmcnabb
txbmcnabb
10
50
Texas
That's how I ran with miine for awhile. Even towing with no clamps on the lower portion of the windshield was no issue.
Reactions: hallic
Mudder
Mudder
NTC Ambassador of Walls
11,650
87,921
Here’s another tip for spider webs.
F012925E FCD0 4BA9 B3F8 64C9B968A515
JayPo
JayPo
Somewhat Well-Known Member
14,255
134,858
Tennessee
Just completed the hinge modification to my SuperATV windsheild to give me farily quick access to removing the hood. And after about 3 hours adjusting the other 20 bits on the windshield I think I finally have it where everything is lining up and fitting good.
2020 11 05 172517
2020 11 05 172526
2020 11 05 172538
JayPo
JayPo
14,255
134,858
Tennessee
Replaced the 2 lower bolts with multi position clevis pins and cotter pins. Now I can access under the hood without any tools in just a few seconds.
1114201659
JayPo
JayPo
14,255
134,858
Tennessee
JayPo, I like your set up! Can you tell me what hinges you used?
They are just some hinges I found at Ace Hardware. I think each side of the hinge is 2" long and 1.5" wide. I drilled holes where needed, rounded the corners a bit with a belt grinder, and painted them black.
Bmurray
Bmurray
438
1,666
Missouri but soon to be Idaho
my fix that uses existing hardware plus a few from @SuperATV and Menards. Just a few mods needed. It works like the upper windshield and now you can access the hood in the field without tools. I'll start a new thread soon with the details.
43lqI50
EbASn9C
CSAhW1a
Mrmachinist
Mrmachinist
Louisiana
QUOTE]
I would be interested in how you did this.
Reactions: MarStar
