I chose the Super ATV full flip windshield and love the design. Works very well and when fully closed keeps the heat in for cold weather benefit. BUT, I missed being able to take the hood off more than I thought and want to use the space for storage. I did a modification that allows the bottom section to tilt. I can get the hood off in about one minute. I’ll post some pictures and description if anyone is interested. Super ATV should just do this and they would sell more!
Sounds a bit silly BUT I canabalized a couple of old common interior door hinges to make the pieces i needed. Then I cut the existing bracket at the bend, brazed the hinge pieces i made to the two pieces (could be bolted).
Lastly, I took out the lower mounting screw and replaced it with a 1/4 bolt with a wing nut brazed to it and brazed the nut onto the clamp part. Seriously, one minute and the hood is off. No change in the stability of the windshield clamping. Hope this makes a bit of sense!
