Eslinger_18
Wake up and piss excellence!
Anyone have any experience with the Superatv 3" lift? Does it change the ride quality at all? Any other comments or concerns? Thanks in advance for any info folks!!
I have a prototype I got from a friend that’s similar to the high lifter so far so good and no tip. I do and would recommend wheel spacers. I have 1.5” in the front and 2” in the back. Also a set of good shocks help this as well. You can see it in my garage post [HASHTAG]#389[/HASHTAG]
P1000m5 - Remmy's Stroker 30 Build And Other Cool Bs!
I’ll see if I can get u a name of it. They were supposed to go into production soon.
Yeah I think that would be just fine. Everything you have there. Good thing about the lift is it’s very easy to put on and very easy to take off If you don’t like it.I've already got 1.5" spacers on the front and rear. And I have the LE model with the adjustable Fox shocks. Do you think that would suffice? I'm not dead set on getting a lift, just kicking the idea around. The machine performs so well now, I'm not sure I wanna risk changing anything just yet. That's why I was searching for some insight from you guys.
I have the Highlifter and it does stiffen the ride up a bit.. I love the ground clearance but miss the bit of travel and ride I had before.I think @JTW had it but took it off because it rode rough and was tippy???
He may have had Highlifter now that I read that carefully.
What size tires are you running. and what is the largest tire recommended with a 3inch lift?I have the Highlifter and it does stiffen the ride up a bit.. I love the ground clearance but miss the bit of travel and ride I had before.
28’s.. you have to have forward aarms to go largerWhat size tires are you running. and what is the largest tire recommended with a 3inch lift?
Agreed! I have 28’s as well.28’s.. you have to have forward aarms to go larger
Are you running factory wheels or aftermarket?I've already got 1.5" spacers on the front and rear. And I have the LE model with the adjustable Fox shocks. Do you think that would suffice? I'm not dead set on getting a lift, just kicking the idea around. The machine performs so well now, I'm not sure I wanna risk changing anything just yet. That's why I was searching for some insight from you guys.
Aftermarket wheels. 14" fuel vectors and 27x10" tires.Are you running factory wheels or aftermarket?
Thanks for the insight. Do you notice it being more tippy?I have the Highlifter and it does stiffen the ride up a bit.. I love the ground clearance but miss the bit of travel and ride I had before.
I haven’t with mine for what it’s worth so far. Don’t know how @JTW feels how his is tho?Thanks for the insight. Do you notice it being more tippy?
I have been running stock wheels and no spacers.. with this setup yes.. it’s tippy. I don’t feel like the suspension has enough leverage to articulate properly. I have forward a arms now and will try going up a tire size and pulling the lift. If it doesn’t suit me I’ll put the lift back on and add the spacers I have.Thanks for the insight. Do you notice it being more tippy?
I ask because I dont know if you knew the factory wheels have different offset. When going to an aftermarket wheel the rear will actually be narrower. You need 1 inch larger spacer in the rear than in the front.Aftermarket wheels. 14" fuel vectors and 27x10" tires.
