P1000 SuperATV lift without spring spacers?
dilligaff82
157
315
New Hampshire
I apologize in advance if this has already been covered, but I did search and couldn’t find an answer anywhere...
I’m looking to lift my Pioneer a little bit to make up for the clearance I lost with the plow mount. I’d like to avoid spring spacers. I’ve been looking at the High Lifter 2.5” kit and the SuperATV 3” kit. I like the brackets a whole lot better on the SuperATV kit, but the kit calls for spacers on all 4 springs.
So my question is this: Obviously it’s possible to run the kit without the spacers, but does anyone know how much lift I’d get with just the brackets of the SuperATV kit?
Thanks in advance.
66,870
Thanks in advance.
Hi.
Assuming you have factory shocks. Yes?
Is your only goal to collect the lost travel on the front? You should reconsider the shock spacers or I highkey recomend a set of aftermarket shocks that you can adjust for winter months. Could also find a second OEM used set cheap and put spacers on them for the winter.
Doing this will let the shocks handle the added load.
Once you done it a few times you can install spacers in 10-20 minuets per shock.
Sorry. I dont have the answers on the SATV lift. I do know most of the lift you get will come from the spacers. At least 1/2 or better.
dilligaff82
157
315
New Hampshire
Hi.
All stock, base model machine. I’ve got no complaints about how it handles in the wonder with the plow on it, I’m just trying to make up for the ground clearance I lost with the KFI plow mount. I never had much of a problem out on the trails before, but it seems like I find a lot of rocks with that plow mount on there. I guess the easiest solution is to just pull the plow mount at the end of the season, but I figured a couple inches of lift wouldn’t hurt either way. Just didn’t want to go a full 3” or affect ride quality with spring spacers.
I’ve got an email into SuperATV, I’ll update this thread when/if I get an answer from them.
dilligaff82
157
315
New Hampshire
Not sure what they mean by this but here’s what I got back from SuperATV:
“Its going to be a 3 in lift over all with the brackets. The spacers and there to compensate for the lift.”
66,870
They dont have those measurements.
I know from the 700. The spacers gave more lift then the lift kit. Ended up taking the lift off.
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Like Hondasxs said i would stay away from the lift and go with spacers. Lift will make it ride like a brick. You can go to a local steel shop and have some steel pipe cut for spacers for aroun 20 bucks for all 4
dilligaff82
157
315
New Hampshire
Interesting. I thought the spacers are what would ruin the ride. This is why I love this forum. Always new stuff to learn.
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
It will stiffen it some...but the lift changes the shock angles and will affect the ride even more so. I ran spacers and lift seperate and together. Lift rides worse
Neohio
Neohio
Beast of the East
14,587
73,832
Painesville Ohio
I believe shock spacers lift at twice the height.
So if you install a 1" spacer, you will get a 2" lift.
Reactions: GlockMeister
