I think I would take into consideration the CV joints as well? A member here had the preload set to high on his springs and blew a couple boots from getting too hot while running roads to get to trails. I got new shocks and set spring sag at 1 1/4 inch, no issues yet. But that's a P1, don't know what the proper sag is for a P5?I have only had my P500 for a few weeks, but was wondering if anyone has removed the shocks, and cycled the suspension to see what contacts first? I came from the Jeep world, and that is a very common thing to do when setting up a new suspension.
Right front cv joint is the first thing to say "uncle".That shaft is so short,the joint will bind some at droop.I put Walker Evans shocks on mine,and my front right would go bump,bump,bump.I moved the front lower shockmounts 1/2 inch further out to clear this up.Others have not had this issue.The WE shocks were only a tad longer than stock.
Yeah ya do,we've been waiting.LoLI still have to check that out!
Mine did not with stock shocks,but,weren't the shocks on 15-16 models longer than the 17-on?TrailBoss is right! There is a bump bump and it is in that passenger side CV, drivers side doesn't do it. I wonder if it did it with the stock shocks?
