Dezrik
Follow me for adventure!
They will need the floor I’m pretty sure. I’ll try to look in the morning to confirm.May have found someone to trade my 1000-5 bed for a 1000-3 bed. Does anyone know if I need to remove the rear floor for them to be able to use the -5 bed on their -3 to make it all work. The parts lookup shows them to be the same but i recall someone saying they were different
I’ll try to get a better pic in a bit.Damn I wish the parts diagrams were more accurate. I cant see this at all
I just checked, the frame is the same on both, it’s the difference in parts for the 5 vs 3. It’s doable, just takes time.Im a idiot, I couldn't find the right diagram for for the "Foot Well" So they are different and I will definately need to include it! The -3 has basically a small engine cover. I don't think I need that part for my setup.
Did you see anything else that he might need? I don't see any frame differences myself.I just checked, the frame is the same on both, it’s the difference in parts for the 5 vs 3. It’s doable, just takes time.
No, the frame looks to be the same, y’all just need to get them sitting next to each of them and swap parts.Did you see anything else that he might need? I don't see any frame differences myself.
Gotcha, ultimately he needs your bed and floor pan. Hopefully you guys don’t come up missing anything from one another.Yeah that would be ideal but we are just driving through and dropping off lol. I haven't found anyone local unfortunately.
He should just need the bed assembly and the floorboard. The side panels (where the full cap is on the right side) should be the same for both 3 and 5.
The only difference is the bed itself and the floorboard. Then ofcourse the back half of the cage as well.
Make sure if you've had the muffler recall done, you get the 3 seat updated bump stops for the bed. The updated muffler cover hits the bed at full tilt without them. He'll want to get the 5 seat stops to get the full lift out of the bed as well.
Why?
