P500 Sway Arm Guard
I
iceboundzeke
26
26
Iowa
The price on these guards are crazy. Thinking about fabricating my own. Any one else have luck making them. Did you do alum or plastic?
gullyjumper
gullyjumper
950
2,413
cookeville tn
I'm with you they are expensive but I haven't made any.
I
iceboundzeke
26
26
Iowa
My goal is to have them made by spring time as I don’t really need them for ice fishing.
208,728
Do P5 owners run sway arms? Mine is laying under my work bench along with the stock shocks?
Reactions: Shadesmn
273,410
I believe the OP really means A-arm guards not sway bars. But I run A-arm guards on my P500 in hopes of deflecting errant sticks from poking into CV boots and the A-arms themselves from hitting rocks. Especially where I ride.
Reactions: trigger
208,728
Well if my stock a arms were laying under my bench, I wouldn't have much ground clearance , ow my they are!
273,410
There are many who have replaced both stock A-arms and shocks, so what you said earlier was entirely possible.
JCart
JCart
895
2,021
Kamloops, BC Canada.
I made my own with aluminum angle, UHMW sheeting 3mm thick, large head pop rivets and some U bolts. Have pix in my link I think should be in P5 mods. Stick stoppers will not protect 100% but will aid for sure. When running in mud or snow you should clean out around the lower boot area as debris will build up there.
Pretty easy project UHMW is great to work with and standard wood working tools will work well to cut, drill.
j
Reactions: trigger and JACKAL
