Switch wiring help
Mhall
12
6
Wiring in some rocker switches and it specifies to ground the switch to make the switch light work. Is it okay to just run a wire to negative side of battery? Or is there a better place. I have the aux fuse box.
Thanks for any help. Yes I’m a newbie in wiring 😁
DRZRon1
DRZRon1
1,450
4,432
ground is ground - battery or a good frane ground - both work -
post a pic of the fuse box, might already have a ground there
Reactions: CID
Mhall
12
6
ground is ground - battery or a good frane ground - both work - post a pic of the fuse box, might already have a ground there
Mhall
12
6
I don’t see anything obvious to attach to. Right next to battery so I’ll use that. Thanks!
Mhall
12
6
New lights for the back. Ordered some more switches for the front yesterday.
