Deleted member 3748
It's good while driving. Once I get moving all you can hear is wind, but you can see the rev limiter kicking in at the 1:00 mark.Looks more responsive than mine
It was working until I sold it. It wasn't set for anything, it just reads the current from the spark plug wire. 7200 rpm would be a lot for that engine... I feel like 3600 is probably correct, but I don't really remember. My 2-strokes rev around 10KHonda,
Is your tachometer still working for you? Is the battery replaceable? I know it's stated it has a 5 year life but it looks like there are screws on the back of it and was curious if there was access to the battery.
I couldn't help but notice that it is reading 700 rpm for idle and 3600 for rev limiter? This seems like exactly half of what it should be. Idle of 1400 and 7000ish red line. Maybe it was set for a 2 stroke motor? And if it was does it have a setting to select 2 or 4 stroke engines?
I have the same one and it's been about three years, still working. And yes, it reads around 700 at idle.
