Hi All,
Unfortunately my talon was ingesting dirty air. Still investigating how this happened, but a local bike mechanic did a leak down confirming the piston/cylinder is the culprit. My talon has 1k miles and is out of warranty. The shop thinks we discovered early enough that other components were not yet damaged but a tear down is needed to confirm.
Compression is 95lbs in rear cylinder and 125lbs in front (4500’ elevation) vs 138lbs spec.
I have two questions:
1) should I go the route of a rebuild vs finding a new engine from a wrecked bike?
2) if I do rebuild, should I go with a high compression (11.5) piston. (I live and ride at 5,000 elevation and would like a little more power without the complexity of a turbo).
Appreciate any advice you have.
Phil
Phil
