Talon Brake Pads
hondabob
1,282
5,090
Prescott Valley, AZ
My Talon brake pads need replacing at 33,000 miles. They cost around $400 for a front and rear set. I check them every 5 thousand miles. I don't use the brakes very often with the excellent decel braking. Occasionally I lock them up just before an unseen washout. I always let off the brakes just before the dip for full travel and to prevent bottoming out the suspension. .
BrakePads
P1K5Dave
P1K5Dave
2,260
8,462
Petoskey, MI
Are the Talon pads the same size as the P1000? That looks like a rear brake, single piston.
5,492
25,269
I recently read that they're the same size and the P1K's are considerably less expensive but don't really have a way to confirm it. If they're a lot less $$, it would be worth it, even if they wore a little faster.
115,818
Thats good to know. Would like to see if its 100% truth. Would save some cabbage.
Reactions: Smittyp and CID
hondabob
1,282
5,090
Prescott Valley, AZ
The part numbers are different for the pads and caliper. HL6 is a Talon number.
Reactions: CID
906UP
906UP
14,399
136,826
da Yoop
I'm on my 3rd set at 4000 miles :oops:
A lot of mud, water & sand in these parts, they wear out fast
906UP
906UP
14,399
136,826
da Yoop
The originals lasted about 1500-1800 miles, ordered some cheap organics (I was in a hurry and needed them fast) they lasted about 800 miles, this last set was some EBC "Race" pads.....whatever that means, they're still holding up but I'll probably be ready for another set this winter.
  • Wow
Reactions: toddvdh and CID
