Talon Door Gap Seal w/ "Trigger Shield" Material / Pattern & Install Instructions
275,453
Contact @trigger for purchasing "Trigger Shield" Materials / Will Also need 24 Honda Fender Clips (Push Pins) - 5/16" Drill bit hole
Materials Needed:
36" x 18" Triggershield Material
Amazon.com
Trigger Shield Door Gap Seal Pattern
1. Open Rear Door, Remove both rubber door stops circled in orange, remove four push pins circled in yellow, and Rear Door latch loop.
2. Slide the material with the square vertical side forward towards door and situate material in red outline, under the plastic where top two pins were removed from. Top across should be level and backside should follow angle of B Pillar.
3. With material situated as described drill or cut out holes in material starting at the top for the four push pins, two rubber door stops, and rear door latch bolts.
4. Re-install the push pins, rubber door stops, and rear door latch loop over the material.
B Pillar Seal Attachment Points Before
If done correctly should appear as below:
B Pillar After Install View
5. Open the front door completely and drill FOUR 5/16" holes in the approximate locations shown below and secure material with push pins.
Front Door Backside Housing Detail
When completed correctly, front door seal should appear as follows with door closed.
20241117 091241
REAR DOORS for 4 Seat Versions
1. Drill the 4 holes in body behind Rear Door first and attach the seal material with push pins.
2. Open Rear Door completely and drill 4 holes in backside of door housing. (with door closed push pins would face each other)
3. Form a U shape with material and affix to backside of Rear Door with push Pins.
Rear Door Jamb  Body Detail
Rear Door Backside Housing Detail
Rear Door Completed view with Door Closed:
20241117 091236
JNo323
JNo323
137
934
Middle, TN
Anyone tried this on a 2 seater? Looks like I could use the rear door template for 2 seater.
Reactions: Coeus
185,525
@trigger hasn’t released the product yet, but I’m sure it will work. My hip was the only thing that got cold when we rode the other day.
Looks like there's a market for them so it has my attention. I'd really like to see these installed first hand before I go shipping them out with my name on them. Got a buddy in the U.P. that I sent some rubber a long time ago for this same mod. Might have to take a ride. 😎
GovtMule
GovtMule
19,928
172,599
Tennessee
I’d definitely be interested as those cracks seem to allow a LOT of air in. (Maybe I just noticed it because it was 30* for our 70ish mile ride at decent speeds!)
275,453
I can get you a pattern, just these 2WD fools that live on the mountain with me can't go 1 mile without getting off the road on ICE. So far I'm at a FedEx truck, Propane Truck, 2 4WD trucks w/ Florida Crackers that didn't know how to lock hubs on a 1995 pickup. An 6 alleged "AWD" SUV's yet I go up and down with abandon, no chains plus dragging their asses.
When I get a break I will take my door seals off and make you a rigid pattern with all the holes and mail it to you.
Hello_Darkness
Hello_Darkness
466
1,931
Just to the right of nowhere
Can I ask why you drilled those holes behind the door when there are available hardware there already?
Not discrediting your work or idea, just curious.
275,453
I did not see any holes present, but I also followed a pre determined path I envisioned by just looking at the layout.
185,525
Awesome. Thanks Jackal, careful one of those a**holes doesn't run you over.
