I have a very little used heavy duty power steering wiring harness (plug & play) designed and sold by Paulf here on this site. This 8 ga wire replaces the cheap 12 ga wire in stock Talons. This helps with power steering stiffness that many of us experience. Here is Paulf's description:
$50 including shipping in lower 48
- I was able to source proper OEM plugs (not CRAP Chinese knockoffs) and wires to replace the inadequate 12 gauge wire with mostly 8 gauge and a few inches of 10 gauge at the motor end. This drops the voltage loss from an atrocious 12% to a more manageable 4%.
- This mod fixes the momentary loss of assist some experience while trying to turn quickly at speed in the dirt. Some (including @TerryH and I) almost wrecked their machines. If you experience this problem, you will know exactly what I am talking about.
- This mod does NOT fix any of the other assist "weaknesses" but it does improve them all. The stock 180/210 Watt Talon system is not strong enough for the size of the car.
- If you run an i4WD bypass, you are never utilizing "Full Power" mode when in bypassed (3WD) mode.
- You can "jump" the ECU to continuous full power (210 Watt) mode.
- IMPORTANT NOTE: More angled than stock front geometry can drastically reduce steering assist. If your front geometry is not stock, you should return it to stock and try again. If you are not on stock tires then for every "actual" inch in larger tire, you should sit 1/2" higher than stock. To determine your actual tire size, use a soft tape and measure the circumference of the tire while off the ground and divide by 3.14.
