ToddACimer Pioneer 1005-2 Lifetime Member Oct 7, 2016 3,812 16,232 113 Oshkosh, Wi Ownership 1000-5Talon X Sep 18, 2024 #1 Looking for a used set of Talon R Dragonfire radius rods Used up is ok as long as the tube is straight. I only want the lowers and I'd like the heims for reference but they can be worn out Reactions: Coeus
CID Well-Known Member Lifetime Member Supporting Member Oct 27, 2019 5,759 26,451 113 SE Denver-ish Ownership Talon R Sep 18, 2024 #2 I understand the need for that gusset but it sure eats up a lot of ground clearance - Reactions: Scoop
ToddACimer Pioneer 1005-2 Lifetime Member Oct 7, 2016 3,812 16,232 113 Oshkosh, Wi Ownership 1000-5Talon X Sep 18, 2024 #3 CID said: I understand the need for that gusset but it sure eats up a lot of ground clearance - View attachment 444414 Click to expand... Agreed, there's some amount of compromise here. They don't make a kit for the x either. The options for a non heim or uniball joint are few and far between Reactions: ChadD, CID and Coeus
