Talon running poor - thoughts?
Code54
Code54
585
635
Hurricane West Virginia
I finally got to take the Talon out for a short trip around the neighbor's farm tonight and noticed it was running very poorly. Sort of surging and would sometimes stall when I was shifting into reverse. When I say surging, I mean I can push the gas 1/2 down, and it seemed to bog, then it may take a few seconds, and it would mostly jump in RPMs and take off close to normal. On some hills, I had very little power and would have to about floor it to get up a hill that is mostly nothing. I also noticed the shifts seemed off, almost like the machine thought it should be picking up speed or going better when it wasn't. I think this is my fault as I have not run it much recently. Like 100 miles in the last 18 months ( I know, I know, - we have 2 SxSs and an ATV, so this has been resting for a bit), maybe, and very very little recently. Would this be normal for bad gas? I think it is and am draining the tank and thought I would refill for 93 and some seafoam - any thoughts? I also didn't throw any codes, which is also what is making me lean towards bad fuel.
Reactions: ChadD and Smittyp
Neohio
Neohio
Beast of the East
14,586
73,811
Painesville Ohio
I would definitely drain the fuel tank and put fresh stuff in it. Might not hurt to put a new set of plugs in as well. They might be fouled from bad fuel.
Neohio
Neohio
Beast of the East
14,586
73,811
Painesville Ohio
If that helps, get the engine nice and warm and perform a clutch relearn.
HondaTech
Spark Plugs
I had one recently that idled weird, and stuttered when holding rpms at just under 2k. It stuttered when accelerating at around that rpm as well, then would clear out.
I pulled the plugs and found the front cylinder to be blackened and sooty. Replaced both plugs and all those symptoms were gone.
5,425
24,913
Use the NGK number 90992 and order from anyone besides Honda, save lots.
1663200283926
Dankathy
296
843
think i would do the gas first, move on to the plugs only if needed. If the gas doesn't smell like gas you found your problem
