Ok. So where is everyone mounting the amplifier for the aftermarket stereos. I bought a boss system and mounted the amp in behind the battery box beside the air cleaner and it didn’t last one ride. I didn’t even take it through mud or water. Any suggestions?
Thanks everyone for the input. Happy thanksgiving
Got the ssv radio and added two ssv pods and put DSI-18 waterproof amp in front of glove box under hood sounded ok and blowed couple speakers then put DSI-18 marine speakers in now she rocksThanks everyone for the input. Happy thanksgiving
I've got a JL Audio MX600/3 amp mounted under my dash in front of the steering wheel. It's a spendy amp, but it has a small footprint and is, essentially, two amps in one. It's got 2 channels for my tower speakers and a subwoofer channel with dedicated sub inputs and tuning controls.
For simplicity, here are Amazon links to all the products I'm using for my audio system as well as some info on my sub box I made. However, I'd recommend reaching out to Chuck Holey with Trailstar Audio to see what he can do on pricing. He can probably save you some money if you buy through him as a package.
Head Unit:
https://amazon.com/Rockford-Fosgate-PMX-2-Compact-Receiver/dp/B0108LNLBK/ref=sr_1_2?crid=21XPSXL08JD8T&keywords=rockford+fosgate+pmx-2&qid=1576685144&sprefix=rockford+fosgate+pmx,aps,161&sr=8-2
Head Unit Mounting Plate:
PBR Products fits Honda Talon 1000 3
Tower Speakers (these things are unbelievable for as inexpensive as they are):
https://amazon.com/gp/product/B01M6DAJ6Z/?tag=sxsweb24-20
Amp:
https://www.amazon.com/JL-Audio-MX600-3-Channel-PowerSport/dp/B07CB25T1D/ref=sr_1_2?crid=WWZ0GD4TQTRP&keywords=jl+audio+mx600/3&qid=1576684928&sprefix=jl+mx600,aps,163&sr=8-2
Subwoofer:
https://www.amazon.com/JL-Audio-10W3v3-2-Single-Subwoofer/dp/B000TDCN2Q?tag=sxsweb24-20
Subwoofer Enclosure - It's a 10" down-fire box that I custom made out of 3/4" MDF using pocket hole joinery and wood glue. It's been sprayed with Rustoleum truck bed liner for a finish and is sized to work so that I can run my soft cargo bag on top of it and also use the JEI Bed Extender to haul my cooler around. If anyone wants specifics on the sub box I have a detailed plan with parts and a cut list I can share.
Kind of ironic you went with JL Audio and then Rockville? JL is awesome audio, RV is basement audio. Kicker makes some wake speakers that will match up to the quality of that amp better. Cost more but you've already coughed it up for the head unit, amp and sub, you're just one step away from loud and clean. FWIW.
Head Unit:
Amp:
Subwoofer:
Amazon.com: JL Audio 10W3v3-2 10" Single 2 ohm W3v3 Series Subwoofer 10W3v3
[/QUOT
Can you share the plans for the sub? After running many scenarios in my head, I'm thinking to get decent sound this type of sub is about all I can do....also how much modification needs done to get the Rockford in there? I have the same unit and looks to be a snug fit....so snug the whole cubby hole may need to be cut out?I've got a JL Audio MX600/3 amp mounted under my dash in front of the steering wheel. It's a spendy amp, but it has a small footprint and is, essentially, two amps in one. It's got 2 channels for my tower speakers and a subwoofer channel with dedicated sub inputs and tuning controls.
Head Unit:
Amp:
Subwoofer:
