Talon X- 14" wheel question
McCarthy
267
537
Canada
Guys, i've heard it talked about here and there and nobody seemed to have a definitive answer if 14" wheels will fit on a Talon X?
I want to run 29x11x14 and 29x9x14. I don't want 30s or 32s as I want to retain factory ish power, but I want 14's to get an extra inch of sidewall, which will help with the brutally stiff ride.
Reactions: TxDoc
Junkyard
29
52
San diego
The system 3 14” wheels fit on my x-4. Ran it in the dunes and all seems good. I think the R has less clearance from what I’ve read.
Reactions: McCarthy
HUCK
HUCK
1,047
2,319
ARIZONA
Cheaper to have Weller Racing do your shocks . Then you will have smooth ride with any size tires .
PaulF
PaulF
1,462
4,814
+1 for Weller Racing. They did a tremendous job on my R.
I run 14" wheels on my R with my paddles but I had to cut down the nubs on the front upper control arms. You should NOT have that problem on an X.
PaulF
PaulF
1,462
4,814
See this post for more info...
Reactions: TerryH and CID
TerryH
TerryH
664
2,241
Springdale, Ar
I've been running 14" Raceline +10 offset on my X since day 1. Never had any sort of issue at all.
Reactions: McCarthy
Sheetmetalfab
Sheetmetalfab
2,172
13,598
Alaska
Yep 14’s on my X4 since October 2019 no problems.
Reactions: McCarthy
Elkhunter
Elkhunter
345
453
Minnesota
What exactly do they do with the stock fox shocks? Do they install different springs too?
