Talon x Shock question
5,684
26,025
Does anybody know the fully extended shock length for the Talon x shocks?. Have tried to search and coming up empty?
I hate telling guys to use the search feature but I'm pretty sure that question was asked recently and it got an answer IIRC. It might show up in a search if you're lucky and choose the right search terms.
Mudwisel
Mudwisel
9,939
82,533
Tampa Bay Florida
I always trying searching first just to keep from asking redundant questions. i am finding all kind of things on spring length ect. I will keep trying. maybe I will find the magic combination of words
115,865
I too would have to take mine off to get that for you.
But it begs the question, you have a P1 whats On your mind with this?
bobbysmores
6
6
NC
On my 21 x4 non LV fox gave me the following
Front Shock 24.70 extended 8.3 travel
rear shock : 27.65 extended 8.25 travel
seems to me that these are 8.5" travel fox 2.0 front. I am working out how to gain more down travel so I had to get those measurements from them. My front cv is at 25 degrees at full droop so im thinking a 10" trvel fox would do well to give me a bit more down limited by a strap
Reactions: Mudwisel and CID
Mudwisel
Mudwisel
9,939
82,533
Tampa Bay Florida
Thanks. I was informed front was about 25. So this confirms that
Reactions: Coeus
SLOWPOKE693
SLOWPOKE693
1,973
7,691
Somewhere in Texas
You need softer main springs to lower the car to the middle of the shock travel if you want to gain anything. Lift kits, longer shocks and all that other fancy jazz isn't going to do what you think it will. Figure out what the main spring rates are F&R and then adjust accordingly.
Reactions: CID
