P1000 Tire and rim offsets
Mykey
Ontario
Hi, New to forums and posting so I hope this is correct. I would like to know if anyone could tell me if I need to use spacers or lift to upgrade my factory tires on my 2018 1000-5 le to 30x10-14 all around with 3.5+3.5 wheel offsets or better to go with 30x10-14 with 4+3 wheel offset.
Thanks
Reactions: BWAF
BWAF
BWAF
I get paid to pass gas
8,864
42,478
Carthage MO
Thanks
From what I've seen imo just do arched forward facing a arms for 30's most are going away from lift for ride .1"spacer in rear and either wheel would work just depends how wide you want it .Welcome to to the addition from sw Missouri. @JTW @Plumber32 @joeymt33 @GlockMeister
BWAF
BWAF
8,864
42,478
Carthage MO
Some are putting 30 10 12's for more ride and flex
Reactions: joeymt33
Thanks
Some 30’s are larger than others. 30” EVOs or 30” Terrabites as well as many others will fit with out a lift and forward arms only. In these cases, the wider front wheels will increase the scrub radius and can cause interference.
Larger tires like the 30” Roctanes will require lift and forward offset arms.
Example: 32” terrabite vs 30” Roctane
53de1c5a0ee60aee1a1f09ce666c08da
Here’s a 30” EVO on with no lift or forward arms and a 5-2 wheel.
9e4eb2502a4eaea5ac456d90a33379dd
It’s close to the inner fender. With a 3.5 wheel or front wheel spacers this tire would be even closer
24490852eebc2a7e9dd19bf074a2035b
Here’s a short 30 and a true 30
1520f7a74e61769c6456b47a5a3c6d57
Hope this helps
Mykey
Ontario
Thanks for the replies everyone lots of info for me to make a decision. As far as my goal and type of riding I do a lot of rock and mud rides, I have up sized tire in the past on honda rubicons and found that the little taller tire helped a lot with not getting hung up in ruts and reduced rock rubs also was thinking an 8 ply would help with the pinching the sidewalls against rocks.
Thanks again
Reactions: joeymt33
