Hi Folks,
I was at BlackRock Nevada last weekend on the Playa where it is smooth/flat for miles. I noticed that at full throttle my Talon would nose over a little, but if I backed off the throttle to about 3/4, it would accelerate. This in in 6th gear about 60 mph. I have the Jackson turbo kit, (not that it has anything to do with it) and that kit came with a "Flash Tool". The flash tool can be used to see RPM, TPS, Temps and other basic info, along with the ability to enter tire size for shift mapping and speedo etc. I had flashed my Talon for 32" tires about a month ago and when I was at BlackRock, the speedo was off by about 7mph at 60, so I hooked up the flash tool to reflash for speedo, and check the TPS reading. At full throttle, both running and not, the TPS reads 78% max. When I back off slowly the TPS % slowly and steadily drops like it should. Not jumping around, but its almost like it needs adjusted (?) somewhere to get full throttle? Has anyone had a TPS go bad, or know of an adjustment?
