P500 Transporting
F
Fischer
209
321
The woods
So what's the majority opinion on transporting pioneer 500. With parking break on and in neutral or parking break on in gear?
NTCPrezJB
NTCPrezJB
President of #NTC
106,232
945,405
Canton, OH
Parking break applied in neutral and then dropped back into first gear for me.
Reactions: Mudder and Fischer
solrus
solrus
1,629
2,511
Montana
Parking break ,4wd and reverse gear
Sent from my SM-G986U using Tapatalk
F
Fischer
209
321
The woods
Parking break on, in 4-wheel drive mode, neutral gear, and tied down. I read my owners manual and ASSUME this to be the correct way described; YMMV.
Yes, guess it looks like more of us should read the instructions. The thing is I read the stuff I though I needed to know in the manual, then I got thinking after I went out on Thursday about this. I was lazy and decided to ask on here instead of looking it up. At any rate thanks for doing what I should of done in the first place.
Swampdog
Swampdog
76
411
53
Forgotten Coast, FL
@Fischer , when I purchased my P500 the guy at the dealership told me to leave it in gear when transporting.
I read the owners manual when I got home. The reason I added ASSUME is because the owner's manual does not say to leave it in gear, but states to try moving the machine back and forth after tying it down. So, I ASSUME that the engine would be in neutral gear.
Someone may come along with a better reason for transporting their P500 in forward or reverse gear.
FWIW, I also hook my winch cable to the front of my trailer as an extra measure of transportation safety. I then tighten down the rear of the machine first, and tighten down the front last.
I'm using motorcycle tie-down straps made by www.thetankstrap.com I've had good results using them so far.
Reactions: Mopower58
F
Fischer
209
321
The woods
Haven't looked at the owners manual yet.....it does say engage 4wd mode? Right?
42,678
Actually, yet again an addendum: mine is in 4x4 too since I have a wood decked trailer that gets slick as s***.
And I think you'd find that to keep the machine from rolling backwards easily, it needs to be in reverse?
NitroxDiver
NitroxDiver
488
918
Concord NC
I posted earlier that I tie it down in gear with the park brake set, I also use 4wd too. I don’t use my winch as a tie down as I destroyed a winch on an atv doing that.
Morpheus
Morpheus
109
362
Minnesota
Very interesting to hear the different ways people choose to secure their machines. The guy at the dealer told me to have it in 4WD with the parking brake engaged and in Neutral. I took his word for it and have used that method without issue, Strapped down with straps of course. He said trailering in gear is bad for the transmission. I have never read the recommendations in the book about it.
lee
lee
Village Idiot
2,377
13,440
Springfield Ohio
I'm wondering why they recommend having it in four wheel drive, if it's in neutral...?
In 4wd the p brake is holding the front and rear diff still. You can argue about the open front diff but once you lift a wheel you have other problems.
Neutral is about not damaging the transmission gears. It’s not that hard on the gears but why push it. Concern is that rocking back and forth on one gear tooth it may damage one spot after 100,000 miles in the back of your truck.
F
Fake_Engineer
21
38
maine
I've been told that using the winch cable can put uncessary stress on the sheer pin in the winch. No idea if it's warranted.
