P700 Tusk TERRABITE 28x10-14
Tim-1000 XT-R
Tim-1000 XT-R
283
899
Oakdale, MN
I'm thinking about getting the Tusk Terrabite 28x10-14 for my 2018 700-2 Deluxe. From what I have read they are closer to 27" than 28". I will need to buy new wheels also and am wondering what offset I should get. I think the stock are 5-2 offset if I remember right. Can anyone confirm that? I would also like feedback on my decision (good or bad). Thanks in advance.
Reactions: Dp5hunter
DBOne
DBOne
34
44
Southern Wisconsin
I just installed (ITP Mudlite ll) 27x9-14 front & 27x11-14 on the rear with 5+2 offset and they worked out great on my 2018 Deluxe P700-2.
Not sure on the 28x10's all around, from what little research I have done seems some work and others tend to rub a bit on front during hard turns.
Tim-1000 XT-R
Tim-1000 XT-R
283
899
Oakdale, MN
Thanks for the reply. I've read that the Tusk Terrabite's run a little small I guess. I read a review that said they love the tires but the 28's measured 27 when mounted. I'm wondering about the 10" on the stock offset in the front. I was hoping someone has tried it. Thanks again. Where in Wisconsin are you?
DBOne
DBOne
34
44
Southern Wisconsin
Ya....too many combos to know for sure on my end as I am a "green horn" in regards to the 700. Wheel spacers could get you a bit more width if 5+2 doesn't work for 28's. Good luck with your search, I'm sure someone has tried this combo a time or two.
I'm in south central WI., south of Madison.
