P500 unstoppable
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
this plow it bolted to ONLY my bumper plate using just 2 3/8th bolts pushing over a foot of snow
20170212 180320
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
That's a sweet lookin pic. Any particular reason you mounted the plow like that?
it was a set up for my rancher that i made fit the p5 and i figured what better way to show the strength of my bumper then to mount the frame to just that alone
U
uconn411
160
255
CT
Wow, that's impressive w/o a diff locker. Any video from pushing the snow?
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
You are a bit west of us, but what we received was a very wet snow. The snow blower was only spiting it about 6'. If yours was as wet, all the more of a torture test for that mount.
Reactions: jak9922
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
its started wet first 4is inches then turned into huge light flakes
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
where abouts are you
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
One of my projects is to make a bracket for my plow on my Rancher(same as yours) so I can us it on my P500. I was looking at mounting it underneath like on the rancher using a piece of flat steel to run from frame rail to frame rail and maybe even use skid plate mounting holes. and then just weld on the tabs to attach the plow.
I love snow and it has missed us in Kentucky this year.
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
you could run steel across then use long square bolts to hold it to your frame them bolt the mount to that . thats what i was going to do at first
Deleted member 3748
Moose uses a bottom mount. Maybe this could give you some ideas.
Moose UTV Bottom Mount Kit - 4501-0486 ATV & UTV - Dennis Kirk, Inc.
